MACsec.PDU.ParmSetSAKUseBdy
Description
This message displays the contents of a transmitted or received MKPDU's SAK Use Parameter Set Body Each MKA PDUs (MKPDU) contains a sequence of "parameter sets": Basic, Live Peer List, Potential Peer List, SAK Use, Distributed SAK. The SAK Use Parameter Set Body is present after the Key Server elects to use MACsec and distributes the first SAK. LKSMI: Latest Key Server Member Id LKN: Latest Key Number LLPN: Latest Lowest Acceptable Packet Number OKSMI: Old Key Server Member Id OKN: Old Key Number OLPN: Old Lowest Acceptable Packet Number Further details on MKA parameter sets and parameters can be found in Clause 11.11 EAPOL-MKA of IEEE Std 802.1X-2010.
Remedy
No action required - Informational message only.
Severity
Debug-Verbose
Message Text
%direction% MKPDU on port %slotPort% [SAK Use] LKSMI:%lsrv_mi% LKN:%lkn% LLPN:%llpn% OKSMI:%osrv_mi% OKN:%okn% OLPN:%olpn%
Message Parameters
Name Type
slotPort SlotPort
direction String
lsrv_mi HexNosByteArray
lkn uInt
llpn uInt
osrv_mi HexNosByteArray
okn uInt
olpn uInt
Applicable Platforms
